Rebel 80psi !
Chippy
Drove truck home all good but felt tires seemed wobbly on highway. Checked pressure when got home 80psi? Aired them down to the 55 front and 45 rear on placard all seems good now but thought how the heck they so high to begin with.
Troop2865
Central Illinois
I have had my oil changed at the fast lube and they filled my tires to the maximum psi on the tire sidewall rather than what was called for on the door placard.
I have found the best way to set tire pressures on oversized tires is to place a chalk mark across the tread section, and then drive for a bit on a hard surface road. If the chalk mark is worn off evenly, your pressure is about where it needs to be. If it wears off more in the center of the tire, the pressure is too high. If it wears off more on the outside edges of the tire, then they are under inflated.
When I ran 37 - 12.50's on my Ram 2500 Cummins, 50 was good in the front and about 38-40 in the rear. If I hauled a trailer or load, I increased the rears to 50.
Chippy
Thanks for the reply. I’ll do the chalk tip!
Kidder
DFW, TX
My guess is the dealer moron who does prep thought it was a Power Wagon.
79 300
The tires are usually pumped up higher than normal for shipping. The dealer is supposed to check and lower them during prep, but many forget to.
