RIC3BOY
- Sep 24, 2018
Read a lot of threads, and searched as much as I could in the forum and on Google, but couldn't find a solid answer to this.
I'm looking to add a 2" leveling kit (ReadyLift 66-1921) and add 35x12.5 tires onto OEM Rebel wheels.
Questions:
1. Would 35x12.5" tires even fit on the OEM wheels?
- My concern is the width. Is 12.5" too wide for a 18x8 wheel?
- I see that the Rebel concept wheels are 18x8 +19 offset (same as the Rebel), and they're fitting a "35" tire on a 2" leveling kit. However, the specs of the tires are 285/75/18. Tire size calculator brings it to 34.8" x 11.2".
2. Assuming that the tires fit onto the OEM wheels, would the wider width tire interfere with any suspension components, specifically the UCA?
- Again, my concern is the width. Would I need to change to a different rim / more negative offset to push the rim/tire away from the suspension?
- If so, would staying at a 18" rim still clear any obstacles (given more negative offset), or would I really need to increase rim diameter (move onto a 20" rim)?
And for those wondering:
- Yes, I like the OEM wheels.
- I want a subtle lift just to clear 35's.
- I like meat on tires, so trying to avoid going up to a 20" rim.
Questions:
