Rear window leak
Ls15
So I know this is a known common issue on these trucks . I have a 2019 Laramie 1500 with 48k miles and tonight the rear window is leaking and has a crack on both sides . I will be taking into the dealership tomorrow but before what are your experiences with this outside of the 3/36 warranty period .
Here I was 3 years later and thought I got lucky and completely avoided this issue 🤦‍♂️
stebo
I just had mine replaced out of warranty last week. Great experience and hassle free. They even hooked me up with a loaner. Truck had 42K miles at the time. PM me and I will get you in contact with someone directly in customer care.
brian42
San Diego, CA
@Ls15 I would take him up on that. That's the first I've heard of a rear window being replaced outside of warranty (that wasn't at the owner's expense).
JJRamTX
Colorado and Texas.
They probably won't cover it unless you had it replaced under warranty like mine was. The replacement cracked and leaked and then they replaced it again out of warranty and the new one has no cracks and seems to be a better design. 2+ Months in and no cracks or leaks.
stebo
Not true. This was the first time I took mine in for the problem. Ls15, I just replied to your PM with contact info. Good luck and let us know how it goes.
Ls15
Thanks , I will reach out tomorrow. Dealer just hit me with a 1700$ price tag for replacement
brian42
San Diego, CA
stebo is the first one I've heard of getting this taken care of by the dealership outside of the basic warranty.
This is why I kept an eye out for it and started pestering my dealership the moment it looked like I had the problem. It took a couple of visits but they did replace the window before I hit 36k miles.
Hopefully they split the cost or take care of it for you.
stebo
I spoke too soon. My truck is leaking again. Worse than before the "fix".
Blizzen
NH
Me too. I have a life time warranty and they are denying coverage. We will fight it.
Blizzen
NH
Hi, May I have that info as well? I visited the dealer yesterday (Mon, 26th) for the leaky window. They see 2 cracks in the molding above the window. We have a life time warranty and they are denying coverage. No reason. The dealer even went to bat for us and argued with the warranty group. They have recommended we call RAM direct.
IvoryHemi
Lifetime warranty through the dealer or are you referring to the MaxCare lifetime service contract?
bourgeois
I went to the dealer 2 days ago and showed them one small crack. My window does not leak but the dealership said ram will pay for a new glass
brian42
San Diego, CA
The STAR Case specifically says that if the crack(s) exists above the slider frame then to replace the rear window, leak or not.
