LaxDfns15
So before I dive more into my rear suspension than I already have (or take it to a dealer), I wanted to ask. My issue is that my rear passenger side is 3/4" higher than driver when measure at the wheel well and 1/2" higher when measured at bump stops. A full tank of gas affects it at most 1/4" (tested with 15 miles left and at full). I would be fine with 1/4" of difference, but the 3/4" is very noticeable.
So far I've taken the springs out, compared and, measured them. They were both the same part number and same height of 20.5". Just for kicks I swapped them to make sure it wasn't an issue with spring rate. Nothing changed when I reinstalled everything and jumped on the tailgate a few times to settle the suspension.
My next question before I start messing with it. Is the track bar adjustable in any way? I've tried to find info on it, but all I can find is stuff on aftermarket adjustable ones. Could this be causing the suspension to torque over? I am new to Ram and especially new to not having leaf springs on a truck, so this rear suspension has me stumped.
