Hello,
I have discerned that the lock actuator on the rear left door of my 2019 Ram 1500 has failed and needs to be replaced. I have sourced the part and removed the outer panel of the door but am struggling with removing the second inner panel to access the defective part for replacement. I don't want to make a mistake and cause damage to other components such as the window and its motor.
Does anyone have any material they could share to proceed from this point? I believe the next step is detaching the window regulator, but any resource I can find on YouTube, etc is for an older Ram generation. Any help is appreciated and thanks ahead of time.
Mike
Mike
