Rear left door lock actuator replacement
brodowi1
Hello,
I have discerned that the lock actuator on the rear left door of my 2019 Ram 1500 has failed and needs to be replaced. I have sourced the part and removed the outer panel of the door but am struggling with removing the second inner panel to access the defective part for replacement. I don't want to make a mistake and cause damage to other components such as the window and its motor.
Does anyone have any material they could share to proceed from this point? I believe the next step is detaching the window regulator, but any resource I can find on YouTube, etc is for an older Ram generation. Any help is appreciated and thanks ahead of time.
Mike
This video should help you out
Sent from my SM-S918U1 using Tapatalk
Thomasp4920 I appreciate the response. This is for the prior generation, but I will see if this will help.
This is a great video, but unfortunately, there is enough of a difference that the systems are totally different. Thanks again.
I dont know about the latch but instructions for the inner card are in the passive entry thread….
