Rear door lock issue
brodowi1
Over the winter, my rear drivers side door lock stopped functioning via the electronic lock and unlock system. The plunger worked, but it was extremely tough to push down and pull up.
Fast forward to about a week ago and the plunger pulled out of the door. Now I have a rear door that is locked and closed. I am unable to open the door to pull off the panel and work on it. Any tips or help is appreciated.
Scram1500
Can you screw the plunger back on? They are threaded, could be stripped. Maybe try using the plunger from the other side
