Had snow over night, turned on my rear defrost and it did not work.
F47 source side has switched power to it, fuse is good, load side reads open to ground with an ohm meter.
Rear glass heater strips are about 14 ohms to ground IIRC, no voltage on the input side.
Looks like the next step is to pull the drivers side rear seat and check input connection to the glass.
Comments/suggestions appreciated.
