Readylift 69-1935 3.5" SST LIFT KIT not compatible with Rebel, but....
LITTLEREBEL
South Louisiana
I purchased the Readylift 69-1935 3.5" SST lift kit before learning its not compatible with the Rebels extra 1" lift from the factory. Can I just swap the 3.5" pucks for 2.5" to accommodate for the difference? Has anyone done this?
3.5 will total to 4.5 on the Rebel. This puts rim center hub to lower fender measurement greater than 25". It will not work because of the CV axle angles exceeding the range (22-25"). I did the research for mine as well. If you want to still use the kit don't add the spring spacer, just put the top spacer, not both.
