Morenar
Been waiting to purchase and came across this nd pulled the trigger
This is not an open box item. I checked with Amazon to be sure.
There are a lot of threads on this forum about that if you search. Some folks install it as is and say ride is a bit firmer others say it's just horrible. Most people will leave the preload spacer out of the kit and use the bilstein 5100 adjustable instead to get the remaining lift. That ride is supposed to be much better. It also depends on the tires you go with.Is anyone familiar with this setup? Maintain factory ride?
