ReadyLIFT 3.5 factory 20” wheel question
Bufo
I’ve been reading post all week but still not 100% sure if what I was thinking will work. I was going to go with the ReadyLIFT 3.5 keep my factory 20” wheels and run Nitto 35/11.5R20’s. Has anyone done this without any rubbing? Mostly concerned with the UCA rubbing. Haven’t seen anyone running these wheels with the lift. Maybe for good reason haha.
Those are 20x9 wheels with a positive 19mm offset. This is the standard offset for all the RAM 20x9s that I've seen, so if you see anyone else running the factory wheels with your tire and lift setup, it would be the same for you.
I would add that Readylift says 295/65-20x9 +18 offset fits our trucks with that lift. 295/65-20s work out to 35.1x11.6 inches. Seems like your setup would work.
You’ll be fine. 12.50’s won’t work but 11.50’s will
Couldn’t you run 35x12.50x20 if you added a spacer?
I am debating the 3.5 and the mopar lift. I have the same rims as the original poster
Nice looking truck! Could you measure from the center of the wheel to the fender in the front?
When I have a little free time I’ll measure it. I didn’t measure before the lift so I don’t have that one.
I imagine you could without a problem. I went narrower for weight also. Saved close to 50 pounds going narrow between the two tires I was looking at.
Did the larger tires throw off the speedometer reading?
so mine was off for like 10-20 miles but auto corrected itself. I read somewhere in the forum that the UCONNECT with navigation automatically corrects itself. I was going to ODC flasher but havent had the need to now.
Truck looks great! Any other pics from front or back? Where did u read that the speedo corrects itself? That’s a new one for me.
I will find a link but I am certain it was in the 5th gen forum
