Rattle sound in cooler temps
Nels
Wisconsin
Looking for ideas to cure my mystery rattle. My truck has what I can best describe as a rattling noise, or a very light clunking, that comes about when outside temps get down to about 40 degrees. Any little bump in the road will cause it. All summer long in warmer temps I never hear it.
Its location is hard to pinpoint from inside the cab, but seems like it's nearly right underneath me most of the time
A dealer said the culprit was a Plastic wheel well liner so they replaced it. Didn't help. Any other ideas that I can look at?
My truck does the same thing. I have had it to the dealer several times and eventually gave up. I think its in the steering wheel, air bag module or clock spring. Let me know if you figure it out.
I should add, the dealer repaced my steering wheel, BUT canabalized all the parts, so buttons, air bag module etc was transplanted into the new wheel. Did not fix the issue.
Bringing this thread back to life because I dtill haven't found the problem. Anyone else having this issue and/or can point me in a direction?
