2019ramshortbedcrewcabguy
- Dec 31, 2018
I did my first oil change at 5000 this past weekend. Filled with Amsoil sythetic 5W-20 and changed the drain plug to a Fumoto valve. Used an OEM Mopar oil filter.
Everything is fine and dandy, much smoother engine meaning I really needed an oil change. Oil pressure is normal, varies between 30-60 psi. No leaks.
However, I noticed two times now that about 5 minutes after startup/into a trip, there's a in-cabin beep (same beep if you put it in park). There seems to be a message that flashes on the dash, but it's gone so quick I can't see what it is.
Anyone have any idea what this might be? Might have nothing to do with the oil change, it just didn't happen until after the oil change.
I wonder if there is a way to look at a log of dash messages?
