Rambox and Cab Protector Rack
Snicklefritz_76
NJ
I've been searching for a cab protector rack that I could mount a couple off roads lights to. I ordered a 1500 with Ramboxes, haven't received it yet so hopefully current owners can chime in.
Can the Mopar Cab Protector Rack be mounted to a bed with Ramboxes? The base looks pretty narrow, like it wouldn't interfere with the Rambox opening and closing but per Mopar it is not compatible. Is it just a matter of drilling holes?
Part available here:
Did you end up finding an answer to this, or finding a similar product compatible with RamBox models? Let me know, thanks!
So far no. I ordered my truck in November but it's still build status at the factory. Once I actually have it I can take measurements and figure something out.
Just wondering if ever you had found a back rack that would work with the Ramboxes, or if you discovered a way to modify the Mopar back rack to fit?
After taking measurements it appears none of the available ones will work. Unless I fabricate my own rack it looks like it's a no-go.
