RamBar on 2021 Rebel
J2daWall
I'm seeing different information surrounding the RamBar for the Rebel. Has anyone on here installed the RamBar on their Rebel? If so pics would be amazing.
My truck is on order still, but looks to be almost ready for hitting the rail yard. Getting close!!!
azMO
I had the dealer install mine. if your not installing the LEDs on them its a simple install. if installing the lights then you have to get the wiring in the cabin to install the on/off switch in the dash. it all comes with detailed step by step instructions.
J2daWall
Any pics? I'd love to see how it turned out for you. Are you happy with it or have any issues?
NewLove
Can you have a tonneau cover with the RamBar?
azMO
No... not easily at least. check out the pic here and you will see the lip of the rambar goes where the rail of the tonneau cover goes. I had to remove my tonneau cover to fit the rambar with the intent to have this retrofitted together. Im not too confident anymore that this will work though. I might be selling the cover.
azMO
yes very happy! I love the look and the lights are 4800 Lumens which is crazy bright! you can certainly put lights elsewhere though like the grill.. this is more about the looks for me. I had to sacrifice the tonneau cover though as both wont fit together without some magical custom fabrication. another issue to be aware of is the added height as the stock Rebel was just able to fit into most garages and now wont fit in any regular sized garages or underground parking.
azMO
I'm about to order the ram bar my self but waiting for the TRX 5" LED part numbers
is there a difference between the exisitng 5" Mopar LED lights and the TRX ones? the part number for just the lights is: Part Number : 82215274AD and the mounting bracket is: Part Number 82216127AA
see link here for all the info:
https://store.mopar.com/accessories...off_road_5_inch_led_light_kit_82215274AD.html
detailed instructions here specifically for install on a Ram will show you what your up against: https://www.imagesmartdealer.com/mopar_accessories_isheet/K6862994AB.PDF
Hope this helps guys. :)
J2daWall
Good call out on the added height, thanks! Do you happen to know how much additional height the lights/bar added to the top of the cab?
ya3coub
Doha - Qatar
Man you just killed me,
Amazing color and car
Mine is blue as well and the only one in Qatar.
I have all the part numbers but if you see the TRX photos you will see 4 led lights, two in each side of the rambar.
I’ve always knew it will look amazing, I now have it set for the rambar as well as the lights with their brakets.
Next step is to find the trx optional wheels part number, and have them in one order.
azMO
Oh NICE!! & congrats on the exclusivity of the Blue in Qatar! I have yet to see any other Hydro Blue new Rebels in person yet in Toronto area where I'm from.
I see what your saying now about the TRX Rambar/LED lights... though they are the same as I posted... you can mount the Rambar with no lights or add as many lights as you like... all the same part numbers regardless of the type of Ram it is. So you buy the Ram Bar and as many of the Mopar lights as you like ;)
I do believe the TRX wheels are available now at least they are in North America as the TRX has hit the dealerships! Personally I will be going with an aftermarket wheel for the nice weather and keep the stocks for the winter snowy months that we have.
Stacy
Just installed the Rambar on my 2021 Rebel. Was also able to put on a soft tonneau cover, Tuxedo X15, with very minor modifications.
Stacy
Was able to put a soft roll-up tonneau cover , Truxedo X15, on my 2021 Rebel with Rambar with very minor modifications.
Whiskeymike
Anyone that has one of these, can you tell me what diameter tube it’s made from?
NewLove
Good to know. Does that tonneau have a track running up the inside of the bed?
