Would anyone happen to know the polarity on the 2 pins of the bed lights or the pigtail harness that connects to the lights??  I have a 2025 so Alpa obd is out the window. Im planning using a spade type connector directly to the light socket pins, then pot it with epoxy. Then doing a direct to battery connection using the button to turn em on & off. I picked up a set of the brighter replacement lights cheap, their oem quality, but no pos or neg markings??  Or if someone can check polarity at finale pigtail connector going directly to lights, Id really appreciate it.
