rain sensor
bobf5761
hey guys, rain sensor not working, went thru display to settings and made sure rain sensor is on,
still not working, went back turned off ignition, reset setting to off, disconnected battery let sit 30min,
reconnected battery and reset setting to on, still no work
Do you still have the factory windshield?
I assume it has worked before. Have you tried different sensitivity settings on the stalk?
When you set the rain sense on have you tried pushing the mist button ? Sometimes on mine I set it and then after a little bit I push the mist button and just seems to wake it up .
Are you turning the wipers on to the lowest intermittent setting? The rain sensor on mine isn't activated when the wipers are turned off which makes sense to me. Sensor definitely works when wipers are on lowest intermittent setting as the timing changes depending on how hard it is raining.
^^^ this
I have mine on the highest intermittent setting, right before it clicks into Low, and the auto wipers work all the time.
