radio question??
RAMTEXAS
Texas
Do your folk’s radios shut off immediately once you turn the truck off or does it occur when you open the door after shutting the truck off?? TIA!
Turns off after a several seconds after I shutoff the truck or after I open the door. But I think you can change it in the settings.
i thought it’s supposed to turn off after i open the door too but it shuts off immediately as soon as i hit the engine stop button.
Have you checked the settings? I believe there is a setting under the engine category.
As mentioned, the engine delay should be on by default, but maybe it was switched before delivery.
It should turn off about 30 seconds after shut-down regardless of what you do, but right away if you open the door when selected.
Your USBs should be live for 1 hour after shut-down, they reset if you open your door for another hour. The 12V on the dash should power off after shut-down.
Its a setting.
You have a 2022 so you have UC5 not UC4.
I can take a picture of the setting if you are still looking for it. I have mine set for 10 minutes (or when the door opens)
