As mentioned, the engine delay should be on by default, but maybe it was switched before delivery.
It should turn off about 30 seconds after shut-down regardless of what you do, but right away if you open the door when selected.
Your USBs should be live for 1 hour after shut-down, they reset if you open your door for another hour. The 12V on the dash should power off after shut-down.
Its a setting.
You have a 2022 so you have UC5 not UC4.
I can take a picture of the setting if you are still looking for it. I have mine set for 10 minutes (or when the door opens)
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
