even better - shows you how often I use it hah; just every now and then to hold say 4th/5th in a climb, then tap up to shift at rev points I likeActually, If you hold the limit up (+) button for a second or two, it will turn off the limit. So there is no need to keep tapping it to get it to go past 8.
Hi guys my truck is 1 week old and this am seems like my radio volune isn't working? Also on accident I hit the gear limit button pulled over and went back to D1 where should they be at please advise thanks
Didn't know that! Thanks for the info!Actually, If you hold the limit up (+) button for a second or two, it will turn off the limit. So there is no need to keep tapping it to get it to go past 8.
Start with the easy stuff...put it on FM, and see if the volume worksHi guys my truck is 1 week old and this am seems like my radio volune isn't working? Also on accident I hit the gear limit button pulled over and went back to D1 where should they be at please advise thanks
Did you have your phone connected via USB with android auto by chance?
My truck had a bug where it locked out my volume control and sound was only coming out of the passenger side. I disconnected the phone and plugged it back in and everything went back to normal.
I have a S9 with android auto enabled. If it comes back again I'll bring it up to my service department. Darn computer bugs!
Note 8 user here; same problem on multiple occasions; mostly when a call hangs up on me rather than I hang up on a call; hard to replicate but it's happened multiple times
