I'm currently running my Valentine 1 from the lighter plug in the center Top of the dash. It looks bad with all the wires exposed. Also, the plug is unswitched so I have to turn it on and off manually. I believe I can remove the panel with the instructions provided in the "installing a factory...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
