I don't see what all the fuss about "the sway bar in the way" refrain. A quick wipe and brake cleaner spray should take care of it in like 15 seconds, as you said.I just did another oil change on my truck, and it's literally next to no mess with the standard drain plug. No funnel or aftermarket valve needed.
Just leave your oil cap on tight, along with the dipstick, even with hot oil, it will come out in a nice easy controlled stream. Near the end, it will hit the sway bar, but barely make any splash, a quick wipe with a old rag and it's nice and clean. As the oil drips straight down, go ahead an loosen your oil fill cap and pull the dipstick up a bit to help finish the drain.
Now, if you have skid plates, and especially something like the Skeerdy Cat transmission/catalytic shield, then something like a Fumoto with a hose attachment would be worth it. That's what I plan to do tomorrow with my first oil change (at 2,500 miles), followed by the Skeerdy shield install.
It's the darn oil filter I need to experiment with. Hopefully, the one-two ziploc bags trick would work well. I do have a Qwork funnel with a 24" flexible steel tube that I'll test first for clearance and ease of use.
I mean, sway bar or not, it's nice to just turn a valve to drain the fluid as opposed to unscrewing the drain plug and dropping it in hot oil, potentially rolling into the hole in drain pan and plugging that so the oil doesn't go into the pan. Then you have to reach into hot engine out to retrieve the plug before the oil spills over the side.I don't see what all the fuss about "the sway bar in the way" refrain. A quick wipe and brake cleaner spray should take care of it in like 15 seconds, as you said.
Depends on how level your driveway is. It hits the bar and splits 2 differnet directions for me. enough that I can only get 1 stream in my 16 qt oil pan.Just leave your oil cap on tight, along with the dipstick, even with hot oil, it will come out in a nice easy controlled stream. Near the end, it will hit the sway bar, but barely make any splash, a quick wipe with a old rag and it's nice and clean. As the oil drips straight down, go ahead an loosen your oil fill cap and pull the dipstick up a bit to help finish the drain.
It's not the problem of the oil on the bar, its where it goes from the bar. See above ^I don't see what all the fuss about "the sway bar in the way" refrain. A quick wipe and brake cleaner spray should take care of it in like 15 seconds, as you said.
I have never dropped the drain plug into oil. How do you do that? Let go of the plug while you are unscrewing it by hand after breaking it free with a ratchet or wrench of some kind? (I use an M12 ratchet with a flex head socket holder to loosen it first). Just push the plug in while you unscrew it and when it gets close every half spin try to pull it out until it goes and poof, no oil on anything.I mean, sway bar or not, it's nice to just turn a valve to drain the fluid as opposed to unscrewing the drain plug and dropping it in hot oil, potentially rolling into the hole in drain pan and plugging that so the oil doesn't go into the pan. Then you have to reach into hot engine out to retrieve the plug before the oil spills over the side.
You haven't changed your oil on a hot engine enough if you haven't dropped the plug at least onceDepends on how level your driveway is. It hits the bar and splits 2 differnet directions for me. enough that I can only get 1 stream in my 16 qt oil pan.
I don't have a lift and I don't jack up my truck so it's not like I can just quickly move if oil starts going weird directions.
As for the oil filter, are you using the regular filter or the SRT?
If it's the regular you can use an oil udder XL and some plastic tubing from Home Depot to unscrew it and let it drain into your pan no baggies needed
Yes I have. I don't put my hand or arm I the way of the oil. You should bring the plug up and away when you remove it not down.You haven't changed your oil on a hot engine enough if you haven't dropped the plug at least once
Yea this works perfectlyI don't see what all the fuss about "the sway bar in the way" refrain. A quick wipe and brake cleaner spray should take care of it in like 15 seconds, as you said.
How do you "I loosen the filter then spin it off with a towel and drop in in the oil catch can"I don't either, 2 years of oil changes and no mess and certainly not one that warranted spending money.
I don't even do the Ziplock trick, I loosen the filter then spin it off with a towel and drop in in the oil catch can. Wipe the mounting surface off, screw on the new filter, done. Throw the old filter in a plastic grocery bag then into the oil filter box then into another plastic grocery bad and leave at Autozone
Just changed oil/filter and it was easier than I expected. Used a single 1-gallon ziploc bag (had another handy but didn't need it). Had to mangle the factory installed filter a bit to get it loose, even after idling the truck for a few minutes.That definitely makes sense for those applications.
As for the two zip lock bag method, it works great, the half or 1 gallon size zip lock is ideal. Position a small pan next to you to deposit the bags as you remove them. After you break loose the filter, turn about 1/2 turn. Slip on the first bag, make sure to slide on the bag all the way until the bottom of the bag is touching the bottom of the filter. Then keep unscrewing until you see oil coming out. Wait about 20 seconds, then slip off that first bag.
Slip on the second bag, again push all the way up until the bottom of the bag is touching the bottom of the filter. Complete the removal of the filter, as the filter drops, hold the bag as oil will come out of the mount for about 5 seconds or so after the filter drops, then slip off the 2nd bag and put into your waiting pan.
Super easy and clean, done it 4 times already, cleaner oil change than even my old Lexus.
There was enough clearance rearward to the axle (4x4 5.7L) to move new filter in position without spilling oil pre-fill. I used Mobil1 M1-113A oil filter and Valvoline Advanced 0W-20 Full Synthetic.
Drained the oil and installed a Fumoto valve with the Skeerdy Cat plate in place. Made a bit of a mess, but the cleanup was easy. For future oil changes, of course, I'll be using a clear tubing from the Fumoto to the collection pan.
My only concern now is the just under 1/2" clearance between sway bar and Fumoto valve. I'll keep an eye on it for a few days.
I have check mine a few times now. Going into 6th month since the install. All good so farJust changed oil/filter and it was easier than I expected. Used a single 1-gallon ziploc bag (had another handy but didn't need it). Had to mangle the factory installed filter a bit to get it loose, even after idling the truck for a few minutes.
Your sway bar shouldn't move that muchJust changed oil/filter and it was easier than I expected. Used a single 1-gallon ziploc bag (had another handy but didn't need it). Had to mangle the factory installed filter a bit to get it loose, even after idling the truck for a few minutes.
Back in prehistoric times, when I was a Chrysler dealer mechanic, The lube guy had a factory over tightened filter once. It took him about 3 hours to do an oil change. He used multiple filter wrenches, to no avail. He then tried large channel locks. They just mangled the filter. He drove a large screwdriver all the way through the filter, to try to twist it. It just ripped the filter can, but didn't budge. He ended up having to cut the entire can off, and then use a hammer and chisel, to turn the base, by inserting the chisel in the holes in the base, and beating it until it broke free.Just changed oil/filter and it was easier than I expected. Used a single 1-gallon ziploc bag (had another handy but didn't need it). Had to mangle the factory installed filter a bit to get it loose, even after idling the truck for a few minutes.
I was lucky then. Being cautious, I actually made sure the filter started loosening before I touched the drain plug.Back in prehistoric times, when I was a Chrysler dealer mechanic, The lube guy had a factory over tightened filter once. It took him about 3 hours to do an oil change. He used multiple filter wrenches, to no avail. He then tried large channel locks. They just mangled the filter. He drove a large screwdriver all the way through the filter, to try to twist it. It just ripped the filter can, but didn't budge. He ended up having to cut the entire can off, and then use a hammer and chisel, to turn the base, by inserting the chisel in the holes in the base, and beating it until it broke free.
You're killing me! Teasing us with tales of easy oil changes in half trucks.I don't either, 2 years of oil changes and no mess and certainly not one that warranted spending money.
