Question on light
loncstrong
So i have a 2023 ram 3500 and a light came on that I can't find anywhere. Can some one please tell me what this means and keep in mind I was not towing anything!
HDRams.
I think it was you I responded to on another forum (different user name), but I’ll post it here too, since it applies to any ram truck with blind spot monitoring:
The blind spot monitoring system auto detected a trailer length. A trailer does not have to be hooked up for this to happen. It will usually happen when someone is following close enough behind you through curves or a turn that the system thinks you have a trailer in tow.
Thank you Jimmy for explaining why the light appears.
Any way to turn this off or is just stoping and restarting the van the only option ?
