LGBarnett
I am in the process of upgrading the speakers on my 2019 Limited with Alpine sound. I have been reading many threads/comments here on how to do this and what pitfalls/issues to be aware of. Due to the numerous threads I have settled on the Infinity Reference speakers (3022s front & center, 9633s rear doors). I see many folks also changing out front door speakers but decided to keep the stock ones there. Thanks for those helpful postings.
My question is regarding the ANC (active noise cancellation). I have read that the front speakers are not used for ANC because they are crossed over for mids and highs only and therefore no impacts due to replacing those. I have also read that replacing the rear sub definitely impacts ANC. The front door woofers also seem to impact ANC but maybe not always? I have not read any definitive comments on rear door speakers impacting ANC. So I did a little research and it seems that ANC in auto environments work best for low frequencies; how low, could not find anything definitive. I also figured out with my ear that the rear door speakers are either full range or even crossed over because I hear little or no low freq bass from them. So my thinking is that if you avoid changing the front door woofers or the rear sub you may avoid ANC issues. Does anyone know definitively which speakers are part of the ANC feature?
One other tidbit I learned is that the speakers need to be in reverse phase of the ANC sound source in order to work. I have read where folks have changed polarity back to in phase which I suspect would have caused ANC issues.
I am still waiting on the correct speaker adapters for the dash. I got the Metra 71-050 from Crutchfield as this is what was recommended, but they only fit the doors. Had to get the 72-7902 for the dash. Anyone see issues with these?
