It isn't a matter of context. Maybe you misspoke and didn't actually mean "his truck won't pick that up" or "he probably doesn't have porpoising in the first place." Heavy duty trucks aren't magic. He didn't miss that. He specifically addressed it and accounted for it.
Oh it definitely is context. I wrote about having a porposing problem. Then I said "and his truck won't pick that up because he probably doesn't have that porpoising in the first place.". What do you think "that porpoising" refers to? Obviously the problem referenced immediately before. Could I have written "and his truck won't pick that up because he probably doesn't have that porpoising problem in the first place.", yes, if that's what you're stumbling over then just stop as I've attempted several times now to explain what my viewpoint actually is.
That won't fly. I also directed you to the 16 pages where I've documented my experience with the two hitches and with the Ram and a heavy duty truck.
And now I'm asking you to make your point: what does your experience with the two hitches and a heavy duty, have to do with me preferring the andersen as it fixes my porposing problem?
That's fine. I agree with him. You seem to take issue with that, which is what I suspect drove your earlier snark.
Well gee if it's fine then stop arguing against it. Evaluating pros and cons of several hitches, then picking what works best for you in your situation is a smarter thing to do then just blindly buying the most expensive product of the shelf.
I'm still hoping you can do something as simple as admitting you were incorrect.
Let me know when you've actually found something that's incorrect, vs you just misunderstanding what I wrote. As a helpful summary of my views:
- different hitches have different pros and cons, pick the hitch that best aligns with you and situation as there is no "this hitch is best for everybody".
- heavy duty trucks are far less susceptible to issues that can plague half tons, such as porposing and sway, and and naturally when you test 7 products on your heavy duty truck that won't necessarily translate or expose their strengths and weakness when running the same hitch/trailer on a half ton. A lot of heavy duty's can pull smaller rv's/trailers without a WDH in the first place, no porpoising, do you think a crappy WDH is going to show its problems when evaluated on that heavy duty? Course not, but put it on a half ton and suddenly its a different story, because you absolutely need that control now.
