PanzerFreak
- May 25, 2022
Hi,
I have a 2019 Bighorn 4x4 (v6) with about 40,000 miles on it, bought it certified preowned. The other day I noticed that my truck wouldn't start. I attempted to charge the battery but no luck (would just sit at 25% on the charger). I bought a new AGM battery, installed it, and the doors and locks worked. My problem now is that the Push to Start button refuses to work for me to put the truck into gear. I can remotely start the truck from the key fob and turn it off but the button is not reacting. I did notice while charging the original battery and after I got the new battery that a "Press brake and Push Button to Start" message is on the LCD, even if I lock the truck the screen and message stays on. That screen being on (one in front of the steering wheel) may be why the original batter changed. For now I disconnected the new battery.
My issue sounds fairly similar to the one below. Has anyone else had this problem? Would you recommend I attempt to replace the push button or have it towed to the dealer? I do have coverage to have it towed under my warranty.
Thank you
Thank you
