Leos_mamalona!
- Mar 25, 2023
can i use a procharger from an etorque engine on a hemi?
So is it ok? Would it work and fit or are there any mods that need to be done? Is because i have been looking for a procharger and found one affordable but it is for an etorque engien and i a have a regular 5.7 hemi 2020It’s been done. I think @Ellisstrong might have been the first.
I believe the etorque procharger works just fine on the regular one as the main difference is that it’s a stage 2 kit with separate belt. You can upgrade a regular kit to a stage 2 anyway. You will just want to get with procharger to make sure.So is it ok? Would it work and fit or are there any mods that need to be done? Is because i have been looking for a procharger and found one affordable but it is for an etorque engien and i a have a regular 5.7 hemi 2020
Good luck!Ok thanks guys i will be contacting procharger!
