Problem with back two windows and sliding rear window
evan262837
Hello all, so over the past few months occasionally my back two side windows won’t work and my rear sliding window but the front 2 always work. I took into service and they ordered a new motor and two switches for the side windows but that still didn’t fix it. I had to take it back before they could fix it and so I’m bringing back later this week. The tech seems to think it may he a lose wire somewhere so he will have to take apart the door panels. I also did a test where I went over a steep speed bump and it worked after. So my question is, is there somewhere I could look myself to possibly fix it. It’s a 2022 ram 1500
I can comment on rear slider.
If the motor is clearly trying to work but window seems jammed, ita likelu off track / needs dry spray lubricant. I used 2 methods.
If you have long arms or can get help, from back aeat activate the switch while you push/pull in that direction.
Another time I noticed a cord/rubber piece bowing in the window... I applied gwntle force to slide the window to eliminate the bow. Once i did that, the the motor worked the window.
Applying dry ailicone lubricant spray seems to have remedied the rear window.
That method worked with my prior 2004 F150 rear slider.
I also applied lubricant to power moon roof before any apparent issue.
Good luck.
