Power window switch stuck up?
Rollint
Has anyone had this happen? The only function that works is auto down. Can't roll down incrementally and can't roll up...however using the driver side master control all function is as usual. Anyone pull this switch out? If so, best method? Might give it a look and try to fix because I'm on a road trip and the passenger would like their window to work in a brand new truck lol
PowerJrod
Las Vegas NV
I would try some of that spray electrical cleaner stuff and work it into the switch before attempting to remove it. Could just need a little oiling...
PowerJrod
Las Vegas NV
Or take it into a service center if that doesn't work. Under warranty....I wouldn't bother taking it apart
Rollint
I'm very doubtful this has a lubricated hinge.
Rollint
Could be that..wont know for sure unless you either take the panel apart or just bring it into the service center. I still recommend bringing it in though.
Yeah, thats why I was wondering if anyone knew the best method for getting the switch out
