Thumbs5th
- Mar 13, 2021
I learned the lesson about deploying the power step in the auto wash- don't do it. The driver's side step broke off. The front bracket, with the motor, had one of the two arms break and the rear had both break. Fortunately the rear is a passive bracket and the assembly is "only" about $180. The front/motor bracket is about $350+. The local welder was able to repair it for $60. During the disassembly/repair we had to loosen the 10mm bolt which indexes/holds the motor drive shaft to the bracket assembly.
When it comes time to reassemble there are several things which can go wrong:
1) The brackets can apparently be slightly misaligned and cause the system to bind. I had to loosen all 6 nuts and get the system working properly then tighten them, checking after each bracket/bolt to make sure it wasn't binding the system.
2) The 10mm bolt is a bugger to get re-indexed. If it is in the wrong location and tightened the system will not work properly. I had to loosen it quite a bit to get the motor to run without faults. I would run the step out ("deploy") and snug the bolt down a bit then close the door and manually assist the step to retract. Hold it in place and tighten the 10mm some more. Repeat until it is tight enough to operate properly then snug it down. No idea on the torque for any of it.
Cheers.
Cheers.
