Power Running Board Help
I guess I should update this. I should have a long time ago. I got the steps to work I put the stupid pin in the fuse box in the wrong terminal so it wasn't getting any power. I was looking at the directions upside down lol.
Once I got that swapped they worked just fine. Best item I have purchased for the truck. I love them.
Thanks all for the help.
Where did you ever find the missing grey connector?
I never did. I shrink wrapped the pins and luckily they have enough grab to hold the pins in the module and then I taped them into the box. Worse that could happen is they come unplugged. I fixed them so they wouldn't short out.
PM me if you still need/want that connector...
hello i had purchased the oem running boards and had to buy harness and module seperate... i have everything hooked up but having an issue with the power that goes in the fuse box... i had pulled everything apart and the spot where the wire is suppose to go i already have a wire in there from the factory... a purple wire with red tracer anyone know what I can do?
directions wrong move to the other connector besides it looks the same
This is not true.
The directions are correct and were correct for me. I just looked at it wrong. Pay close attention to the pic in the directions. I was confused on the pic orientation and put it in the wrong spot.
Don't spread B.S.
Did anyone get the part numbers for the harness and the control module? Also anyone have pictures of the instructions? I have this part #68422689AB for the harness but every time I look it up it says it's for a trx and not my rebel.
For anyone looking for the two connectors that go to the control box under the dash, they can both be ordered from Mouser.
Black: https://www.mouser.com/ProductDetail/Yazaki/7283859930?qs=yqaQSyyJnNiHvKWDU4HgCQ==
Gray: https://www.mouser.com/ProductDetail/Yazaki/7283839840?qs=yqaQSyyJnNh9MpXEI9L1Sw%3D%3D
I was looking for the gray connector and the dealer told me it was only available as part of the wiring harness at $320. Got if from Mouser in 3 days for $17 including shipping.
Old thread, but your links lead to the same product.
Weird that clicking the links takes you to the same page since each link has the correct product IDs in it. I redid the second one and it seems to be working now.
Awesome. Thank you for this. Found a set of just boards and motors for cheap. Looking to put it all together myself.
