NatGNJ
Hello all,
I just went through the process of installing a new audio system. I did the process stage by stage to avoid the DSR1 install until I had replaced the speakers, added the new amplifier, new subwoofer, and had most aftermarket work completed. Yesterday, I go to install the DSR1. As usual, I disconnect the battery and proceed.
I know my signature has details, but vehicle info: 2019 1500 Crew Cab V6, base 6 speaker (no ANC, no amplifier), 8.4" Uconnect w/ NAV. I purchased a DSR1 w/ DCH3 harnasses, and I followed their instructions to the letter. The only soldering I performed was for the speaker wire and the 12v Amplifer on (I tied into the cigarette lighter circuit, which goes off with ignition from my experience). I did not remove fuses or tap into the harness for the steering wheel. All power was run for subwoofer and amplifier prior to the DSR1 install and the stock components were working fine. All power connections were performed while the truck's battery was disconnected (positive run without connection until I was ready to terminate). DSR1 has the vehicle specific firmware. MY DSR1 install configurations is said to require the CANBUS connection, which I connected at the driver's side above the parking brake.
Back to issue. I reconnect the battery, and go to start the car. Engine starts. But the CEL comes on, wipers are moving at minimum speed (adjustment will not work), Info center and cruise controls are not working on the steering wheel, Message states that the START/STOP is disabled as well as 4WD system.
I did what I thought was a wise troubleshooting maneuver: I disconnected the battery, than all DSR1 connections and reset to factory, reconnected battery, and tried to restart the truck. Same issue.
I'm at a loss. Does anyone know what I need to do (or check) to try and reset the systems on the car? Getting the DSR1 set and working is a secondary goal now. I need the other systems working first.
