I’ll admit that I’m not the smartest when it comes to lift/level kits. My understanding is that the 2inch pre load spacer needs to be left out on the Rebels but the rear is still 2 inches. So technically the front will be raised 1.5 inches and the rear will be raised 2 inches. Wouldn’t that make the rake even worse than it is right now? I would need 2 inches in the front to level it out but I’m only raising 1.5 while raising the rear 2 inches also.. maybe I’m over thinking this? Looking to purchase the kit with the first responder discount as long as it will level it out with some lift.
