Cmerkert
Found this excellent online Towing Calculator for Travel Trailers. It made it very easy. click here
One question. For trailers with 2 axles, the Vin/Specs sticker lists the axle weight as 4400 lbs per axle (GAWR 4400 each axle). In the spot for entering Axle Weight, do I enter 4400 or 8800 lbs? Not sure if being dual axles makes you have to double the number to 8800, or if the axle rate is just 4400. Any axle rating experts in here?
