I have a 2021 Ram 1500 3.0 ecodiesel with the 235mm ZF rear end, limited slip with a 3.92 gear ratio. 67,000 miles I’ve checked on mopar for a new axle shaft, as the bearing has chewed part of it, causing some awful noise. When I looked up the rear right axle shaft, it shows multiple options and does not indicate any difference between them. Part numbers are as follows:
