My front sensors are no longer working after I installed a aftermarket bumper. Does anyone know if the factory needs to adjust them or should I just turn them off ?
Dealer won’t touch them since you’ve changed to an aftermarket item. Or if they do it will cost you. Did you connect them or use extensions from the chassis?
Ive been arguing with the manufacturers and the dealer about the issue. it is $169 per sensor for the factory to reset/ adjust them. Has anyone else had this issue with after market bumpers?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
