Parking sensor issues
Medgas24
My front sensors are no longer working after I installed a aftermarket bumper. Does anyone know if the factory needs to adjust them or should I just turn them off ?
Dealer won’t touch them since you’ve changed to an aftermarket item. Or if they do it will cost you. Did you connect them or use extensions from the chassis?
Ive been arguing with the manufacturers and the dealer about the issue. it is $169 per sensor for the factory to reset/ adjust them. Has anyone else had this issue with after market bumpers?
