GTG2022
I am adding front and rear park assist to a 2022 BH. I am trying to pin the connections under the drivers side firewall. I believe this is one of the connectors I need to pin. I was able to seperate the two halves but how do you get the connector off of the bracket? Half of the connection sits on a plastic bracket. I can't figure out how it is connected because there is no space between the bracket and the firewall. Without removing it, it is nearly impossible to see where the connections are to go. To those that have added park assist, how did you pin the connections? Does anyone know what this connector is called so I can look it up on connectors.dctools?
