I painted the hood vents and the trim piece between the grille and the hood body color.
I left the texture on the hood vents, but removed it from the trim piece.
Hoping to do the large hood bezel next, but it will have to wait until spring.
you'll need to remove the hood line to get to the vent tabs. Then release the tabs one at a time while prying the vent away from the hoo with a plastice trim tool.
The trim pieces come off the truck as one assembly. remove the radiator cover (a few plastic push pins) to expose the pins and bolts. remove the plastic push pins and 4 or 6 (cant remember now) bolts and the piece will slide out.
You can probably tape it off at that point or completely disassemble it. If you decide to break it down into deperat parts, be careful and take your time. there are a LOT of clips and you don't want to break any.
I used spray can touch up paint from automotivetouchup.com along with their adhesion promoter. I also used a can of 2K clear on top.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
