6 speaker basic system. EcoDiesel, so no ANC under the seat. 8.4 stereo. Installed this module a few months back with the new(ish) PAC AP4-CH42 harness for the '22s. Connected to an Audiocontrol ACM-4.300 and out to some Kicker 6.9s in the doors, 3.5s in the dash with resistors (regretting not spending the extra for a crossover set up, but that's for another time). Using factory wiring harness with adapters at the speakers. All components Crutchfield purchased.
I'm on my second PAC AP4-CH42 module and still having the same problems: 1) fader control works side to side, but I get nothing out of it if I put everything to the front. Fine if I leave it in the center (all speakers) or all the way back (back speakers only). 2) PAC advertises that you will lose speed sensing volume control when installed, I actually GAINED it. I don't care for that function, never have, and I turned off the function at the head unit and still have it after installing the module (it successfully turned it off prior to any modifications). 3) Connections at the amp don't match those at the module. ie: red on the module doesn't necessarily match to red on the amp if I want the speakers to be represented correctly at the fader controls.
To be clear, I have set the HU to "amp mode" and have been in touch with Crutchfield who referred me to PAC directly. Talked to them a couple of times on Saturdays when I've had time to mess with this. They're stumped and I'm now just chasing problems by replacing things. Told me to replace the CH42 harness to see if that works. I could see that maybe affecting fader if it's faulty, and will try that next, but not seeing it how it would affect the speed sensing volume. Lord knows I've been wrong before...
I'm no audio installer, and I'm old. Maybe someone that's more up to speed with the newer tech can give me some places to check? TIA
