skid_valve
Recently bought a 2021 ram 1500big horn 5.7 hemi with e-torque, I noticed it had a slight vibration at idle but it also had a cracked passanger manifold.
The other day I finally replaced the cracked passenger side header with the bd diesel replacement one, and immediately noticed the idle vibration got worse along with now getting a p219B check engine light code (bank 2 air fuel ratio imbalance) that comes back event after clearing.
What could this be? I’m worried about it being a valve train issue or maybe 02 sensor, idk how to reset the fuel trims but I do have alpha obd if it’s possible to do it with that. It is about to get an oil change as well if that’s important for context, any help is appreciated especially if it might be an issue with these engines I don’t know about especially seeing my truck is higher mileage at 167,000mi.
Thanks
-Skid_valve
Thanks
-Skid_valve
