P219b code and rough idle after replacing cracked header Help?
skid_valve
Daytona Florida
Recently bought a 2021 ram 1500big horn 5.7 hemi with e-torque, I noticed it had a slight vibration at idle but it also had a cracked passanger manifold.
The other day I finally replaced the cracked passenger side header with the bd diesel replacement one, and immediately noticed the idle vibration got worse along with now getting a p219B check engine light code (bank 2 air fuel ratio imbalance) that comes back event after clearing.
What could this be? I’m worried about it being a valve train issue or maybe 02 sensor, idk how to reset the fuel trims but I do have alpha obd if it’s possible to do it with that. It is about to get an oil change as well if that’s important for context, any help is appreciated especially if it might be an issue with these engines I don’t know about especially seeing my truck is higher mileage at 167,000mi.
Thanks
-Skid_valve
Thanks
-Skid_valve
I don't see how the header could be causing this? (Pardon for the font size...)​
Possible Causes
INTAKE MANIFOLD LEAK AT A SPECIFIC CYLINDER ON BANK
EXHAUST MANIFOLD TO CYLINDER HEAD LEAK AT A SPECIFIC CYLINDER ON BANK 2
FUEL INJECTOR ISSUES AT A SPECIFIC CYLINDER ON BANK 2
IGNITION SYSTEM ISSUES AT A SPECIFIC CYLINDER ON BANK 2
CYLINDER COMPRESSION IMBALANCE
CARBON BUILD UP
VARIABLE VALVE TIMING ISSUES
VALVE TRAIN ISSUES
O2 SENSOR.
Possible Causes
CARBON BUILD UP
VALVE TRAIN ISSUES
O2 SENSOR.
I mean I don’t either, but by fixing the manifold it got rid of the massive leak it had 🤷‍♂️ I just got my missing hardware to install the driver side header maybe it’s a slight difference side to side causing it. If it were valve train what would it be?
Good question
To add to it.. I also got that code after I fixed the manifold issues it’ll turn on for a few hundred miles then go off then reappear again eventually. Haven’t had time to really dig into it and figure out what could be causing it.
Good question
Did you replace both or just one ? Also did your idle get rougher?
Both but a day after each other and didn’t drive it far enough to notice anything. I haven’t noticed anything different with the idle but ill keep a closer eye on it next time it pops up.
Thanks for the info if I figure it out I’ll share it here and if you figure it out please do
I've worked through both of these issues on my truck as well and they were independepant issues.
My first question is, does your truck ever idle perfect, even just briefly? I ask because mine would, sometimes for a tank or two, sometimes only a partial tank but it was capable of idling smooth at times. This ruled out any worn cam, valvetrain or other permanent severe mechanical issue that RAMs can encounter. So I was able to narrow mine down to fueling/combustion issues. I switched to better fuel, higher octane and did a full tune-up at 100k miles but the ultimate solution for me was to run a couple bottles of the Chevron fuel system cleaner through it. I figured I had gummed up injectors but I also know I took on a bunch of water at a remote fuel station out in the country one day. I was about to drop the tank and do a thorough cleaing but the Fuel System Cleaner did the trick and it hasn't come back. Currently at 138k miles and it idles so smooth you have to check to see if its running at times.
I thought mine could be gummed up injector related when it originally happened shortly after manifold replacement my tank had been sitting low for a while. I ran the code P219a and misfire I think on bank 1. No noticeable driving difference other than the CEL turned on. I tighten the two bolts on manifold to CAT some more did the soapy water test and ran the truck no noticeable leak so I caulked it up as a fault code especially since it occurred shortly after the manifold replacement. I refueled and short drives during the week it eventually went back out. It eventually popped up again several hundred miles later but I wanna say the misfire was a different cylinder this time.. same thing drove it around enough during the week eventually went back out. Drove it a few weeks ago from FL to VA it probably popped back on within a hundred miles or so left.. been staying here driving around tike here and there and its back off. Im positive its not valve train related so ill probably just start running a few tank with injector cleaner and monitor it from there.
Putting some injector cleaner through it probably isn’t a half bad idea. I’ll change out the other header and put some in to see if it goes away, if that doesn’t work I’ll pull the injectors and put them on my flow bench
My first question is, does your truck ever idle perfect, even just briefly? I ask because mine would, sometimes for a tank or two, sometimes only a partial tank but it was capable of idling smooth at times. This ruled out any worn cam, valvetrain or other permanent severe mechanical issue that RAMs can encounter. So I was able to narrow mine down to fueling/combustion issues. I switched to better fuel, higher octane and did a full tune-up at 100k miles but the ultimate solution for me was to run a couple bottles of the Chevron fuel system cleaner through it. I figured I had gummed up injectors but I also know I took on a bunch of water at a remote fuel station out in the country one day. I was about to drop the tank and do a thorough cleaing but the Fuel System Cleaner did the trick and it hasn't come back. Currently at 138k miles and it idles so smooth you have to check to see if it’s running at times.
GREAT NEWS!! It’s fixed the only thing I did was put a bottle of seafoam injector cleaner in the tank right before a fill up did 20 miles and the light went away and has stayed away for a good bit now!
The truck oscillates more at idle then I think it should still, but it may just be what it is normally and I’m just making a mountain out of a mole hill regardless steel feels the same same in that regard.
I still have to put the driver header on but I feel better now!
Update it’s not fixed the check engine comes and goes but it def still idles rough sometimes rough then others. I wonder if the cams have issues or something
Run another bottle of fuel injector cleaner through it and see if it clears up again. Mine will still act up from time to time so I end up doing a treatment every couple months. I've been researching how to properly clean injectors and have been considering pulling them to do a proper deep cleaning. I don't think the treatments do an adequate job, they just buy you a bit of time.
A guy should probably just buy another set of injectors and swap them out for new. I priced them out but couldn't pull the trigger.
It might be beneficial to remove the throttle body and clean behind the butterfly. Carbon build up here can result in erratic idle as it can disrupt idle air flow knocking the air metering off kilter. Simply spraying seafoam in the throttle body only may not remove all of the deposits behind the butterfly.
Comrades, I have changed the manifold several times. Each time, there was a risk of damaging the oxygen sensor wire on the driver's side. There is no risk on the passenger side.
What do the plugs looks like?
Update For everyone That attempted to help me here I have officially fixed it! The cause ended up being the upstream 02 sensor had gone bad, I guess the cracked manifold had been letting enough air into the stream to partially messed the o2 sensor so when it was fixed and getting the correct afr it was reading bad. I replaced both 2,000 miles ago and it has not come back even once. If yall need it the Driver side 02 sensor is part number #68224424AA and the Passenger side part number is #68290528AA, Genuine Mopar ones are available from rock auto for wayyy cheaper then anywhere else I saw.
Good luck everyone!
