ORP with a lift kit
HotStuff
Just a couple of questions...
Picking up a new level 2 Big Horn with the ORP, and was wanting to do at least a level. I don't really want a total lift kit, but I'm concerned with the angles of everything since it already has the factory 1" lift. Will 2" spacers and upper control arms do it? Then I might do a mild 1" in the rear. Depends if it's higher in the front than the rear when I'm towing. Any suggestions?
Same truck, Level 2 Big Horn with ORP. Readylift 2” Level, 34” tires. Boat is about 3500 lbs. Slight rake, maybe 1” when not towing.
Readylift 2” Level with Upper Control Arms.
Guess I should've read your signature...lol
Any idea how big of a tire will fit with that 2"? I'm picking up some of the 20" polished Laramie wheels to use. I'm just thinking about some 33x12.50's. I know they'll clear, but debating about going taller.
My tires are 34”. I do believe I could get a 35” in there without rubbing but I didn’t want a “stuffed” look. I did not change tire width from factory however (10.8”) as I wanted the steering to feel the same. This is the same setup I had on my 14 and was very happy with.
