Has anyone had trouble with their outside temperature reading correctly? Mine seems to be reading about 10 degrees F higher than the actual temperature outside.
I have also noticed mine be on the extreme high side until driven for awhile. Although one day, it was pegged at 76 degrees the entire damn day despite it being 90 degrees out.Mine was pretty ridiculous during the high temps we had in august. I was seeing temps of 104 listed after being parked a while, whereas the "actual" outside temperature was mid 90s. It does feel less accurate than other vehicles I've had, although I am used to those going high while parked and then returning to normal fairly quickly.
This would mostly explain it. Annoying, but should cool down at speed and eventually read correctly.Outside temp sensor is in the drivers side exterior rear view mirror. May or may not apply to your specific symptoms
