So I wasn't sure whether to post this in the towing section or the hemi section but here goes. This past weekend I was towing my boat (approx 7k lbs) in 100 F heat. On some of the hilly stretches my oil hit 255 F and then when the road flattened it was back to 215 range. I currently am running 5w20 PUP. If i go up to 5w30 will my oil temps lower? Should I be changing my oil now after seeing those temps? I had planned to run 5k miles between oil changes. Also I only tow about 10% of all my miles, maybe even less. Suggestions?
