As far as I can tell, the oil life readout is simply a declining 10,000 mile counter. % life remaining = ( 10,000 - miles driven )/ 100
i have seen no increase in rate of decline when towing a large percentage of time. At 2k, I changed the oil, and the readout showed 80% left (Zero towing and ave 19mpg). At 9400 mi, after 2500 mi of towing at 11-14mpg, and the balance mixed highway/city, it showed 6%. Load, temps, stress, etc had no discernible effect.
I would not assume it is any more sophisticated than that.
Change the oil and filter every 7500mi, use synthetic, and no matter how you drive, there’s little risk...
From
https://5thgenrams.com/community/threads/oil-change.15894/
Post 20
My mpg for my last oil change was 15.01 mpg in 1,363 miles. Like you I had a lot of cold weather starts and short trips and had my worst mpg of 10.38 mpg on my last tank (best 16.49). Calculating my oil life worked out to 7,000+ miles, very similar to your experience. This was with conventional oil.
I did an 893 mile trip bringing my son back to college. Minimal stops going and no stops coming back. The mpg (vehicle display) for the trip going was 21.2 (400 miles+, 1st tank of gas) and 20.7 coming back until I did some local driving which dropped it down to 20.3.
I had just changed the oil prior to this trip (full synthetic PUP). The oil life now reads 92%, which calculates to 11,163 miles oil life. I believe it is going to change any mile now as 91% would drop it down to 9.922 oil life, which is more in line with oil changes.
As per page 165 of the owner's manual:
The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate, dependent upon your personal driving style.
What exactly is measured and calculated in "duty cycle based" is unfamiliar to me. I do know my mpg goes down dramatically with cold weather starts and short trips and can watch it drop. I have just started to calculate the "oil life" with oil changes. With my current info it appears 7,000 - 10,000 miles. I'm sure it can be reduced just by being a city driver only. And although the math works out to 11,000+ miles as per above I am sure it will drop down shortly to 91% and 10,000- miles.
Summary:
7,000 mile oil life, conventional oil, distance 1400- miles, avg mpg 15, cold weather starts, short local trips.
10,000 mile oil life, full synthetic oil, distance 900- miles, avg mpg 20, minimal starts, highway.
I am interested to see if the full synthetic has an impact on my mpg with cold weather starts.
FYI if you want to read more.
Performing all scheduled and recommended maintenance on your Ram is imperative to keep it running well, so you can avoid the many untimely, inconvenient, and possibly expensive repairs that come from neglect. Luckily, the days of...
www.yourmechanic.com
