CHeYeNNe71
Depends how long it's been that way, because oil can deteriorate radiator hoses, particularly those made of standard rubber. The oil can break down the rubber material, causing it to swell and potentially fail.
That's certainly a consideration. I would also add the amount of oil in the cooling system and how long it sits without running is just as important in your formula. Remember that hot coolant circulates through the system when he engine is running. So the oil could be constantly washed off and redistributed in other areas. I would think the coolant would have to have mostly displaced the coolant to affect the rubber hoses enough to warrant replacement. But again, this is my opinion. If it were me I'd reuse the hoses and keep an eye on them. If I noticed any leaks forming I'd replace the hoses myself. No way I'd pay labor for any of this, including replacing the oil cooler.Depends how long it's been that way, because oil can deteriorate radiator hoses, particularly those made of standard rubber. The oil can break down the rubber material, causing it to swell and potentially fail.
