I'll try to answer the questions and address comments.
"what's the benefit of running 2 filters instead of 1?"
Well, there's much more filtration area with two filters.
I was going to use a single remote filter, but I already had this double unit floating around the shop.
"So you need to buy double the amount of filters each oil change?"
Yep. Every 3,000 to 5000 miles.
"and then add more oil too!"
Oh yeah. Holds more oil now. About 9 quarts.
"You probably get a little more cooling surface area."
It's insignicant. Oil temps still occasionally rise to over 220.
"Buying two filters instead of one each oil change isn't going to break the bank, but I'd rather spend a little more on a higher quality oil filter."
True. That picture was taken just after install and those filters were on a shelf in the shop, so that's what went on.
I use larger WIX 51773 filters now.
"Actually ram does not have an oil cooler at the filter location, it has an oil heater. I am sure id has a double function though. Because it has a coolant attachment, the water warms faster than the oil, thus, they designate it as a heater. Weird, I now, but that's what they call it."
In the version of FSM that I have, it's called a cooler, but it's function is, as you state, to get the oil to engine coolant temperature quickly. So yes, it is a heater, because it can never cool oil below engine coolant temp. It acts as a moderator, to keep engine oil going into the engine at a relatively consistent temperature.
I change the oil and filters on this excellent engine every 3000 to 5000 miles, using quality filters and Rotella 5W-30 oil except in summer for long trips, when I will use Rotella 15W-40.
Oil and filters are cheap compared to the cost of replacing an engine. Mine is 70,000 miles old and still purrs like new.
The subject of oil and filtration has many sides and factions, and the debates continue on the usual oil and lubrication forums about best oil viscosity and oil change intervals.
The choices I make give me peace-of-mind. That's my benchmark.
Steve
