mikeru82
You spread oil on the gasket, not the threads.I used the torque wrench on the filter, but I did not oil the threads.
Lubing the threads make no sense.Gaskets for sure. Some are saying it is not seating correctly without lubing the threads. The torque wrench is breaking too soon
They're not. The whole cartridge is replaced every change and it's all plastic. There's quite a bit of resistance while threading it in. I've done 8 or so oil changes on my ecodiesel and they all went in with some resistance. Lubing the plastic threads helps.Lubing the threads make no sense.
Sounds like people are crossthreading it and then trying to torque it down.
I've been changing my oil my whole life but this thread has completely confused me i'm checking out.
Yes you cant tighten it down more if you want to break it, but thats not the point of my posts.(Why would you even do that???)Except you can 100% tighten it more than when it comes to a stop, all the way until you break it. Also, that’s not the only reason for the low oil light after changing the filter as there are other reasons relating to the oil filter that can cause issues. That’s the whole reason I posted the joke and every other post in this thread. Assumptions you’re making are only looking at a single aspect and concluding that it’s the right and only cause/resolution.
100% correct, sorry for the misunderstanding.You spread oil on the gasket, not the threads.
but you have the hemiI tighten the oil filter as hard as I can hand, then go a smidge further with the filter wrench for good measure
Yup. But I’ve done it that way on everything I’ve owned. Tractors, flat bed f-450’s, etcbut you have the hemi
they have the diesel
Even after lubing up the o-rings the cartridge filter on these ecodiesels you’ll need a socket and wrench to get anywhere, they are a tight fit and aren’t the same as the can style filters you’d see on other motors. It’s kind of a pain to need a wrench all of the way in or out.Yup. But I’ve done it that way on everything I’ve owned. Tractors, flat bed f-450’s, etc
You’re free to do whatever you like, but increasing your rpm on first start up after an oil change is asking for a problem if something catastrophic happens and you don’t notice because you’re in the truck with your foot on the pedal. A suggestion is to start the truck, start counting to 10 while watching the oil pressure on the dash register pressure, then shut it off and check for leaks. If you notice no oil pressure after 3-5 seconds, shut it off immediately and check that you didn’t forget to put oil in the truck or put the drain plug in. I’m sure you’re wondering “why would anyone forget to put oil in the truck, I’d never forget that”. I saw it happen dozens of times when I worked as a tech, and did it myself once. It happens.Even after lubing up the o-rings the cartridge filter on these ecodiesels you’ll need a socket and wrench to get anywhere, they are a tight fit and aren’t the same as the can style filters you’d see on other motors. It’s kind of a pain to need a wrench all of the way in or out.
I tighten the filter with a wrench until it stops and then give it a bit of a snug to make sure it’s not just the o-ring bound up. After installing the new filter and oil I start the truck up and hold the rpm’s around 2000-2500 for 15-20 seconds to leak check.
Definitely happens to the best of us, I do wait for oil pressure to register before holding the rpms.You’re free to do whatever you like, but increasing your rpm on first start up after an oil change is asking for a problem if something catastrophic happens and you don’t notice because you’re in the truck with your foot on the pedal. A suggestion is to start the truck, start counting to 10 while watching the oil pressure on the dash register pressure, then shut it off and check for leaks. If you notice no oil pressure after 3-5 seconds, shut it off immediately and check that you didn’t forget to put oil in the truck or put the drain plug in. I’m sure you’re wondering “why would anyone forget to put oil in the truck, I’d never forget that”. I saw it happen dozens of times when I worked as a tech, and did it myself once. It happens.
