Mine will ping with 87 without fail. 89 is fine unless I'm pulling a trailer. I've actually used UNL88 (E15) without any issues and have the same experience as using 89, it's usually way cheaper than 89 (and sometimes 87) so nowadays I opt for that if available.
I carry two bottles of octane booster in my bed box for that reason. Higher octane seems to be a must when towing anything over 3000 lbs it seems.Same here, 87 is pretty bad and 89 is better but still noticable under load. All the gas I can buy up here is using some percentage of Ethanol, anywhere between 5 to 15 percent. I have not noticed any difference on pinging from where I get the gas, except the one time I got caught in the middle of nowhere with my trailer coming home and was forced to purchase from some small town general store. I was cringing hard for the next 2 hours.
I plan to purchase 3 or 4 gerry cans for next season, and just put them in the bed of my truck for long towing trips. Not getting caught like that again!
Mishimoto seems to have the best mount and location though.A catch can is a good investment, but no need to spend over $100 on one, u less you just like telling people you have (insert name brand) part installed on your truck. This is what I have. It's basically the same thing as the UPR catch can. Has a drain valve in bottom of it so you never have to unscrew the bottom like most require. I empty about 2 oz of crap out of it every 2000 miles.
Black Oil Catch Can Tank Compatible with 2009-2019 Dodge RAM Trucks 1500 2500 5.7L 6.2L 6.4L https://www.amazon.com/dp/B0895FMYGC/ref=cm_sw_r_apanp_SmzJ3etbwLMQW
"Best mount and location" is a bit subjective. Personally I think where mine mounts is more aesthetically appealing when looking under the hood. Also it doesn't work with the Vararam or RamAir intakes.Mishimoto seems to have the best mount and location though.
Hehehe it works with the ram air as well as almost every other catch can.... Horribly. As for best mount I was mostly talking about how generally not mounting catch cans to the engine is a bit better."Best mount and location" is a bit subjective. Personally I think where mine mounts is more aesthetically appealing when looking under the hood. Also it doesn't work with the Vararam or RamAir intakes.
Maybe it was the S&B it didn't fit with. Either way, saying it's the "best" is still subjective.Hehehe it works with the ram air as well as almost every other catch can.... Horribly. As for best mount I was mostly talking about how generally not mounting catch cans to the engine is a bit better.
No the s&b works great with it. You have to basically remove the ram air to get to it or reach under it or install their drain kit. Doesn't work with the varam at all.Maybe it was the S&B it didn't fit with. Either way, saying it's the "best" is still subjective.
So I was correct to begin with. Got itNo the s&b works great with it. You have to basically remove the ram air to get to it or reach under it or install their drain kit. Doesn't work with the varam at all.
Most of it isnt oil, which is why it's not a good thing you dump what you do empty out back into the crankcase.So stupid question here, if your emptying any oil or crud out of catch can are you replacing that oil back into truck with new oil? Seems like it would be running lower oil now right?![]()
Wait ,what you just said most of it wasn't oil why dump that back into the engine then, how can that be good for oil that's clean?Most of it isnt oil, which is why it's not a good thing you dump what you do empty out back into the crankcase.
ReadWait ,what you just said most of it wasn't oil why dump that back into the engine then, how can that be good for oil that's clean?
It's not "all oil" no matter what time of year.It’s all oil in the summer. Winter it’s mixed with water due to condensation build up
And over the course of 5k miles it totals up to about 8oz of oil. From my experience. So you wouldn’t notice it on a dip stick.
